Moza AB6 FFB Base.
19 Dec 2006
UK
£399 including a stick and desk mount, other than the reduction in power output (6Nm rather than 12Nm.) but with the inclusion of a couple of throttle sliders, buttons and a built in z-axis (not entirely sure it's built into the base and not just a function of the included stick actually as the description says stick but the one youtube I've seen on it says it's the base) it just seems like this is a bit of a slap in the face to AB9 buyers.
Edit: Adjusted the power numbers.
That's the sort of price I was expecting but I didn't expect the stick to be included in that. I might get that MHG for my AB9 though as I'm borrowing the one from a Thrustmaster HOTAS at the mo.
It looks usefully thinner than the AB9, which probably helps if you wish to centre mount it.
Awesome stuff.
It's significantly smaller, 188*123*163 as opposed to the AB9 which is 227.9*157*204.5, this video has them side by side at the 5:20 mark:
I like the look of that. Maybe the answer is to put the AB9 to the side for use with the F16, and use the AB6 centre mounted...
specs are good and people seem positive about it. It's a lot less powerful than the AB9 and with a more granular feel so AB9 owners need not feel bad.
I hope Moza do a less powerful forcefeedback yoke too
