- 20 Mar 2007
- Norwich
After using my Sony Ericsson K750i with its 64MB memory card as an MP3 player for the past year, I think it's time for an upgrade. Since I'm already familiar with iTunes, which is what I use as a media player on my laptop, it would make sense to get an iPod, but being fairly new to this I don't know what things out there are better.
My ideal MP3 player would be around 8GB+ (since I have 11GB of music currently, and I don't need it all on there at once, 8GB should be fine), support MP3 and AAC files (since I often encode using the latter when importing a CD using iTunes) and be fairly small. I have no use for a portable video player, so video-playback is certainly not a requirement.
However, If absolutely necessary I can allow some leeway with the above requirements. I suppose it doesn't have to support AAC files; it would just mean I'd have to re-rip my existing CDs to MP3 files instead. Also, I might be able to cope with less storage space--say... 6GB--but this will not be ideal as I'll have to keep changing what tracks I have stored on it.
Basically, I'd like suggestions of what you guys think are descent 8GB+ music players which support AAC files first, and then those that fit my more-lenient requirements if necessary. I don't really want to spend more than £200 on this, if you want some idea of what budget I have.
On a related note, I'm going to want some descent headphones for this. Currently I'm using a pair of DT 770 Pros (I'm a bit of a bass-head, if this helps at all) with my home setup, but I'd rather have some ear-bud or in-ear style headphones, which I know absolutely nothing about in terms of what's good and what's not. So any suggestions here would also be very helpful- again, my budget for these is around £60. Of course, I'd like to spend a lot less if it means only sacrificing minimal audio quality. I'd like them to be very comfortable, and work nicely with a portable music player, whatever I decide to get, without an amplifier.
Thank you in advance.
EDIT: I just had a look around, and it seems only iPods and Sony's NWA808 fit my "ideal" requirements, or are there more?
