MP3 Rip program
if people need a tool to convert flac to mp3 for ipods, there is great tool called foobar. as with most apps that use lame, you need to copy lame.exe into the foobar program directory, but then you are good to go. very fast, and free.
foobar isn't a tool, foobar is an audio player. The best audio player, in fact.
Actually foobar is bot ha tool and an audio player. It's one of the most flexible audio tools there is on windows and can be made to do all sorts of excellent stuff, including burning CDs gapless.
You need the foo_burninate.dll plugin (and I think a version of Nero installed, just the minimum)
Then create your playlist, right click -> burn to CD, and away it goes. Does CDtext and everything.
link about it all
http://www.hydrogenaudio.org/forums/lofiversion/index.php/t9680.html
well that was surely a pedantic post you made there. :confused:
anyway, it is common to refer to a software program that allows a specific action to occur as a tool. there are other things that can referred to as a tool as well but let's not go into that. :p
Anyone know how to add album art using media monkey? When I insert a cd, freedb finds all the tracks ok, but Iam not sure how to add the album art?
