MPC-HC oddness!
28 Sep 2008
Britain
I've updated to the latest build from xru and when I play a file, any type, I get audio and subtitles, but no image.
I thought this odd, so I uninstalled and installed an earlier version but the same things is happening on that too.
Any ideas what I can check?
Chuck this file (right click save it) in your mpc-hc directory, will give you nicer looking controls
Dragging by the screen in the latest nightly seems broken for me, the one on the official site was fine
http://mpc-hc.sourceforge.net/download-media-player-classic-hc.html
I have been using the mpc-hc with all the internal codecs disabled with ffdshow x64 and i am impressed with performance.
Thanks for the toolbar trick, did not know you could do that.
What do i need to get this DXVA working, i have an ati 3850 but when i play x264 it never uses dxva.
Btw, if you use that toolbar.bmp from above, reinstalling or putting a new version on will leave the file there, so you have the controls for good :)
