The car in the OP's post is a REV1. 3K for a rev 1 is way to much. I have a rev 1 in exactly the same colour and i have had to upgrade things like the wheels and the brakes as they run 14's as standard and the brakes are smaller than the rev2 onwards. Also they are run a higher ride height than the later models. I really need to lower mine.
Look at getting a rev 3 or at least a late rev 2 for that price. Check for over heating as it could be something as small as a sticky theromstat to a cracked block.
Rev1/2 run on a AFM so if its got an aftermarket dumpvalve it will run pig rich and will run sluggish and hold back when shifting while booting it. Rev 3 don't suffer from this.
They are great cars though. I love mine to bits and it always makes me smile. A few choice mods like a nice exhaust, Air filter and intercooler and up removal of the T-VIS and fitting a boost controller allows you to get boost through all the gears, although in your situation a standard car will be more than enough.
Treat it with good tyres and respect and it will give you lots of fun.
Heres mine
Heres mine
