Thanks for the replies...
About the lean fuel starvation , if this is the case why is it using so much fuel and with a high idle 950-1000rpm hot , low idle 1100 cold!
The timing was done not so long ago , 3 months we did it ourselfs with a timing gun.
Yes its running 98+ has and always will be , i've had the car for ni on 5years.
MBC no it has an EBC (blitz) 15Gain 52Ratio... The read out was showing 1.11 kg/cm2 = 15.7psi at the time which is just under 1.1. I did turn that down to eliminate the possible cause and it still did it.
