MS Excel Formula Help - Validating Row data across sheets
26 Jun 2005
I'm working on some new spreadsheets and I'm encountering some intermittent inconsistencies.
Workbook A and Workbook B have some customer data on them, unfortunately they are created independently. I'm Copying and Pasting them into a new Workbook C into Sheet1 and Sheet2 respectively. The Sheets have (amongst others) Columns for Customer Name and a Reference Number. They should be exactly the same, so Mr Smith is 12345 and is in Row 5 say.
I'm creating a new Column on Sheet2 which is an IF formula but the output isn't as expected for all the rows. It starts out OK but then some Rows in Sheet1 aren't in the right place, they are 3-4 rows up or down of where they should be.
Is there a way to check that : Sheet1 Row 5 is (Mr Smith and Agreement 12345) the same on Sheet2 and show me where the errors are?
The Sheets are about 600 rows long and increasing each week.
Thanks.
Not sure if I am understanding it quite right, is it the output you are expecting in the new column of sheet 2 is appearing a few rows up or down from where you are expecting? Have you checked exactly which cells the formula is looking at? Might be useful to try using a VLOOKUP to make sure you are getting the right customer data.
Try;
=IF(A5=Sheet1!A5,"ok","err")
That will either throw back an "ok" of they match or an "err" if they dont.
If that doesnt help then as Phantom Shadow said a Vlookup may be a better option....
