Msconfig has gone?!
16 Oct 2007
UK
Went to look at what startup processes i have, as computer was starting up qutie slow (1min after desktop before you could use it)
start..
run..
msconfig..
can't find it?
no luck with searching either!
what have i done? no virus as far as i can tell
How have you checked for a virus, because that sounds like one to me. Msconfig is a popular target for obvious reasons.
plus there's tons of things it misses
disable system restore
remove whatever av you've got now
run..
ccleaner slim
nod32 av trial
spybot s&d
adaware
avg antispyware (remove this after)
put firefox on with adblock plus and Easylist subscription (do this on your pc too)
hijackthis will tell you what's running at startup
Regedit then look in:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
Most stuff goes in there so it's a good place to start looking.
