MSFS 2020 System Spec Build Help
27 Sep 2004
Hi all,
Not been around here for some years and have not built my own system for years either but looking for some help and advice to spec out a system build for myself to run MSFS 2020 simulator.
Not sure on budget yet maybe something around £1,000 ish give or take
As i have not built my own system for so long i am way behind on tech and the current standards out there so any advice would be appreciated suggested build spec
Chris
Hi all,
Chris
what resolution ?
and whats your current specs ? maybe something can be kept etc
Just throwing this out there, perhaps heresy on a PC forum, but if you are just building for MSFS and on a budget it's coming to Xbox series X in the summer.
