Hi all,
I've had the above card now for just over two weeks. Overall it's been a pretty good card. I've run 3dmark and Unigine Heaven / Valley and all seems to be OK apart from the odd stutter sometimes. I did experience some artifacting in Black Ops so I updated my drivers and tried a few other games and all was fine.
I've been using MSI afterburner to cap fps to 60 and in L4D2, Counter Strike GO and Dirt 3 it has been silky smooth 60fps or 59.9. However, I installed Half Life 2 E2 on Saturday to relive some of the old gaming days and I was having issues keeping fps to 60. One minute it was 60 and then it can reduce to 55-50 in places. Surely for a game that is so old now I shouldn't be experiencing that. Yes it's still graphically good but my card should eat it for breakfast.
Anyway, the plot thickens, since putting HL2 E2 on I now get the same issues in CS:GO and L4D2. I can be running round a corner, favela on CS:GO and the fps is 60 then it will drop as low as 48fps causing a bad stutter. I was running 13.2 Beta 7 drivers so I changed to 13.4 and 13.5 Beta 2 and still it happens. I tried turning settings down and even disabling msi afterburner and still it stutters. I tried so many things that I decided to do a fresh install of OS and I still get the issue in CS:GO. Dirt 3 seems to be pretty much constant 60fps but when I change view of car to look behind me it drops to 55fps.
Another weird thing is now when I run Windows Experience Index my CPU and Ram Score have gone from 7.8 to 7.5. Could that be a sign of something being wrong with either of them? Another odd thing is when my machine idles my gpu spikes up to 87% every 10-15 seconds at least 4-5 times and then won't do it for a while and then does?
Any suggestions / help would be great as I was planning on watercooling my PC next weekend but won't now until I know my system is fine.
Many thanks,
RoEy
Many thanks,
RoEy
