MSI Afterburner 4.6.5 (Beta 4)
Caporegime
8 Sep 2006
On Ocuk
Version 4.6.5
Added new MSI Windows 11 themed skins (Light and Dark editions) by Drerex design
Added voltage control for reference design AMD RADEON RX 6700 XT series graphics cards
Added experimental support for Intel 11th generation CPUs
Added experimental support for Intel 12th generation CPUs
Added experimental support for mobile AMD Ryzen CPUs
Fixed issue with missing memory temperature sensor on AMD RADEON 5700 / 5700 XT series graphics cards
Fixed issue which could prevent MSI Afterburner from opening from tray via main application icon after accessing properties via clicking monitoring tray icon
Increased memory overclocking limit for NVIDIA GeForce RTX 30x0 series graphics cards
Added workaround for internal DirectInput issue, which could cause hotkey handler to stop processing hotkeys correctly after locking/unlocking PC from keyboard with <Ctrl>+<Alt>+<Del> or <Win>+<L>. To bypass it MSI Afterburner is resetting hotkey handler state after lock screen transition now
Optimized monitoring profiles switching implementation for situations when profiles contain different sets of data sources displayed in monitoring tray icons
Application tray icon is DPI aware now:
OS level tray icons scaling is disabled now to prevent tray icon text distortion. Power users may revert back to the previous DPI unaware tray icon rendering mode via configuration file if necessary
Added new bigger tray icon fonts for >=150% and >=200% DPI scaling ratios. Power users may also select tray icon font independently of selected DPI scaling ratio via configuration file if necessary
Application installer is DPI aware now
RivaTuner Statistics Server has been upgraded to v7.3.3
Does anyone know a way to get afterburner to show Ryzen CPU effective clock speeds? like HWinfo does so you know the exact speed the cores are running at
Guess he got that MSI payment lol. Great to see it being updated.
No
It's a beta file. MSI pays him to release final versions not betas and he hasn't released a file version in 11 months. The betas just contain work he does for free, and you have to use the beta if you have new hardware because the old final release version doesn't support ryzen 7000, Intel 13th Gen or Radeon 7000
No
And this new version also breaks voltage monitoring/control for Nvidia's 4000 series, That's winning right there, Much success, Many clappings, Very congrats ! XD
Version 4.6.5
I downloaded it and launched Afterburner to checked the version realised I already have the same latest version since 12 Dec 2022 to get RTSS overlay worked properly with Portal RTX. It took Guru3D nearly 2 months to updated the page. I downloaded latest build from Unwinder post on Guru3D forum, I searched the forum found his post dated 17 Nov 2022.
Guru3D created page listed RTSS v7.3.3 on 2 Dec 2021 but never updated page to included latest RTSS v7.3.4 beta 7 was posted on forum on 23 Nov 2022, I downloaded it on 12 Dec 2022 to updated from beta 6 after installed latest MSI Afterburner version.
No he didnt. He still not got that MSI payment so it was Guru3D that took nearly 2 months to updated page. :cry:
I think Hilbert Hagedoorn need to retired. Or maybe Hilbert still not got payment from sales or someone for months to get Guru3D website running.
