MSI Afterburner fan settings ?
16 Feb 2014
North West England
Anyone got a guide for using the fan controller on afterburner ? I just have it on auto atm should I just leave it on that ? Got 2 r9270x in crossfire and don't want the top card getting too hot :) .. But I'm clueless on fan profiles, any help would be much appreciated :)
I level my fan off at 65% at 60 degrees as I don't like it ramping up and down quite a bit. With my crds, you can here an audible difference from 65% to 67% for example and it annoys me fluctuating with cut scenes etc.
Thanks , does it matter if you have it fluctuating ? I have headphones in so the noise won't bother me too much just don't want the card overheating :) .. What's the highest temp I should let the top card get to ?
Try and keep your cards at or below 75C and you'll be fine. The lower the better in crossfire. Just experiment and find what works best for you. If you setup an overlay then you can monitor temps as you game.
