MSI afterburner help
12 May 2011
Southampton
Is it possible for my overclock and voltage settings to be applied, AND OSD server be running, on start up, without having both OSD and Afterburner showing in the toolbar? It is just bugging me that I have both icons in the toolbar/ both programs running. So...
i've ticked the 'apply my oc settings at start up' button. Do I have to have AB running at windows start up if I want my OC settigns to be applied at windows start up?
If I have OSD running at windows start up, will it apply my OC settings?
MSI Afterburner will apply the settings without opening on startup. But for the OSD you need the OSD server to launch and run in the background, closing it will stop the OSD server.
They both hide down in the notification area when minimized anyway, does this really bother you? If you want you can get it to hide via customizing the notification area if you wish, same as all of the other icons (Such as Wireless/Sound/Action Center).
