I have tried that but it seems the LED Visualizer in GeForce Experience only works on Nvidia reference cards.I have had a quick google and you can disable it through the Nvidia Experience software.
don't have a card to test but link below which may help you out
https://forum-en.msi.com/index.php?topic=261575.0
edit.......Just found this website as well, Guide on how to do it without the Nvidia experience software installed.
https://www.reddit.com/r/nvidia/comments/3elvsw/guidehow_to_use_nvidia_led_visualizer_without/
The gaming app has to run at every startup for it to disable the LED.Cant you disable it with the gaming app and then uninstall the app?
Thats how most other manufacturers controlling software works.
