Hello all thank you for taking the time to read this.
I'm having a real hard time with the fans on my gt73vr 7re i just got it on friday the 31st had some very strange issues with this laptop from the beginning.
i have done a clean install of windows 10.
the dragon center and the fans are not working properly for me. if i have it set on auto fan, dragon center says fan speed is 0 rpm !
on basic fan option max, dragon center will state fan speeds upto 1100 rpm
on cooler boost dragon center states fan are around 5000 rpm
my problem is that the auto settings dont seem to be working which is strange. now if i uninstall dragon center and reinstall the auto settings for the fan seems to work ok, until if for any reason the fans need to go near maximum or seems to be anything above 3500 rpm this will cause the auto feature to stop working again to 0 rpm for the auto fan setting.
i currently have 1 workaround with this issue. theres an option for advanced fan control which allows you to pick which speed you want the fans on, i can keep that at medium speed which is good for basics.
http://imgur.com/a/Mo0CV
any advice will help, and thank you in advance
I'm trying to avoid having to send it back to MSI, as i got this in the exchange program.
