Hi,
Would this card be good enough to run Splinter Cell Conviction (@1280x1024) on a system with a dual core intel cant remember model, roughly 12 months old) clocked to 3.4ghz with 4gb ram? OS is Windows XP.
Graphics Engine GeForce GT 220
Bus Standard PCI Express x16 2.0
Memory Type GDDR3
Memory Size(MB) 1024
Memory Interface 128bits
Core Clock Speed(MHz) 650
Memory Clock Speed(MHz) 1600
DVI Output 1
D-SUB Output 1
HDMI-Output 1
HDCP Support Yes
Dual-link DVI Yes
HDMI Support Yes
Display Ouput(Max Resolution) 2560x1600
RAMDACs 400
DirectX Version Support 10.1
OpenGL Version Support 3.1
The reason for this selection was it looked like good value and performance for that money.
Cheers,
Chris.
Memory Type GDDR3
DVI Output 1
D-SUB Output 1
HDMI-Output 1
HDCP Support Yes
Dual-link DVI Yes
HDMI Support Yes
RAMDACs 400
Cheers,
Chris.
