See my other thread here
http://forums.overclockers.co.uk/showthread.php?t=18232244
I discovered on my mobo installation disc that there is a windows-based overclocking utility (control centre 2, not available on msi's site). I usually avoid them so hadn't seen it, BUT it applies the overclock settings and I'm now sitting pretty on an easy 4.7GHz, reported in cpu-z etc for confirmation.
So, if you're finding that your settings aren't sticking (my vcore never stuck) then I can recommend using the utility on the disc (saves rebooting all the time too, except when you BSOD on low volts lol).
Well chuffed
Well chuffed
