- 18 May 2010
Hi,
I have a B450 Pro Carbon, my previous board was a Gigabyte and fan control was simple, set the case fans to System and they ramped up and down with the system temp
This boards fan control is weird, I cant match the fans to System because System sensor never goes over 40C under load so the fans will just sit there at the minimum RPM while the CPU and GPU cook
If I match them to CPU you get that annoying ramp up when using the desktop and browsing etc, also when gaming the fans stay at a lower RPM than needed to keep the GPU cool when gaming
Just wondering how everyone has gotten around this? I much prefer the fan control on my old board but everything else is fine so I want to try and figure it out so the fans are silent in Windows and ramp up when gaming
Thanks
Thanks
