MSI P35-Neo2 overclocking 'problem'
24 Oct 2002
Portsmouth
Hi all
I have a 2180 which after spending all day tweaking I have running at 10x300fsb for 3gig
Now you can also turn speedstep off as I learnt tonight and run it at 8x375 which is also 3gig.
Technically speaking this is better as it has higher bandwidth (although it only actually added up to another 60 3DMarks!!)
However whenever I reboot with 8x375fsb the computer turns itself off twice before starting correctly and continuing to load windows.
This gets somewhat irritating and doesn't happen at 10x300fsb. I wouldn't mind if it was a oneoff, but it's each time you restart!
Any ideas if I'm doing something wrong, or if that particular feature can be changed?
