MSI Radeon HD5870 Lightning
7 May 2006
London, Ealing
It should be a very good overclocker. Look at what MSI did to the GTX275 lightning. They replace the standard pwm and capacitors and normally do bespoke cooling so this card ought to rock.
I was under the impression that ATI were very proud of the fact that their cards did not need two 8-pin connections. . .Perhaps this is just the exception to show what can happen if they let this gen of chip fly.
MSI cards on MSI motherboards work better right? if so this might be for me :)
You think this will demand less or more power? or just the same
" Tier 1 board maker MSI is cooking up a special Cypress-based treat for next year in the form of the R5870 Lightning, a custom Radeon HD 5870. The upcoming graphics card will feature a proprietary cooler (probably a 2-fan solution), a custom PCB that's taller than the one of stock models, and will make use of two 8-pin PCIe power connectors (dual 6-pin on reference HD 5870s), for overclocking reasons.
The R5870 Lightning will likely be factory overclocked and will boast the 'usual' - 1600 Stream Processors, a 256-bit memory interface, GDDR5 memory, DirectX 11 support, CrossFireX and Eyefinity, as well as DVI, HDMI and DisplayPort outputs. More will about the card will probably come about at CES next month so now we wait. Or not "
Probably a 1000Mhz+ core and some good hand picked RAM.
No difference what mobo/GPU brand you have.
More power by the looks of things. I'd imagine it'd ship with a respectable factory OC but be cabable of more, driving consumption up over the reference 5870.
a bugger. Was told that MSI cards have more overclocking on msi motherboards with afterburner :(
Got any pics of the cooler for the car? i was looking at the 275 and it looked mental!
looks good bet will cost major premium as well
Hopefully by the time it comes out there'll be a more plentiful supply of 5870s around (= lower prices).
Nice to see the custom designs starting to appear - I want a shorter 5970 that still vents outside the case :)
looks nice but how can it be wider.. :P 2 of thease cards on the ref board are allready very close together :( ?
