- 29 Dec 2005
Hi,
So i've had this problem ever since I got my Typhoon from OCUK 6 years ago, but its generally infrequent and wasn't a big problem until recently.
Essentially whenever I disconnect the PC from power ( PC is already shutdown and i'm talking about taking the plug out of the plug socket to move the PC or replace a component ) and then say press the power button to remove any residue power in the system, reconnecting to power will cause the motherbaord to think the last overclock has failed. It then displays a custom start up screen before the MB logo screen and before getting access to bios. This screen claims the 'overclock' has failed and allows you to use alt+num or alt+L to load an overclock setting.
Unfortunately this custom screen will not display on my monitor when using display port. It does come up with vga or dvi or hdmi ( sometimes ) and I've no idea why. The problem is now i've got a new gpu that only supports DP or hdmi and so this is beginning to be an annoyance.
Does anyone have any recommendations to address this issue? Either the disconnection of power fooling the MB into thinking the OC has failed, or forcing the custom screen to display via display port.
I guess I could just not overclock the PC, but the cpu is getting pretty old now and though i'd like to get a new build that is proving difficult in these times. The overclock i'm using is the one that OCUK set up on the PC when I bought it from them, so it should be reliable and indeed its never gving me any problems on its own - it seems to be the disconnecting of the power lead that causes the MB to think its failed.
Did wonder if it could even be the PSU, though not sure how.
Any ideas?
Any ideas?
