msn error message + web problems
1 Feb 2006
Hi guys,
I keep getting the following error message when i sign in to msn live messenger.
"Due to a connection problem, changes you make might not be applied to other computers you use"
I clicked on the message for more info but it offers no help.
When browsing the net I also noticed that when i load a web page it frequently says "page cannot be displayed". When I refresh it it loads up fine.
I have recently reset my router so perhaps I have forgot to reset something.
Anyone got any ideas as to what this would be caused by?
Thanks in advance
i have tried this again and again but it makes no odds.
a different problem i have is when using my hub. Occasionally my network will go inactive and i have to unplug the hub, replug it and then repair network. This happens anytime I switch on any other appliance connected to the same power adapter. Very very weird!
edit: i have just solved some of the above problems. My router had been set up with the wrong authentication method!
