Multi directional fans
26 Jan 2008
Basically i need a new 120mm fan, my graphics card fan sits to the left of my cases fan port, about 50% over it, can you buy a fan that you can adjust so it blows air at an angle, i'd only need a slight adjustment but i'd prefer it if i could blast cool air directly at the whole of cards fan intake rather than at half of it
or create some kind of wedge where the top two screw are longer and use something as a spacer for the top two screws, so when u tighten it up the bottom will come in further and angle the airflow down
