Multi Monitor Problem
Suspended
22 Oct 2004
Hi All
I have a pair of HP w19 Monitors on a PCI-E 6800 GT
Clean install of XP and latest drivers
When I plug the second monitor into DVI, its not detected by Windows or NV control panel
However - if I use the analog vga out and then an adaptor at the other end, it is detected, but because im using a splitter its a poor quality image and only NV Control panel detects it - not Windows
I think I need to select DVI input from the on screen disply, but this won't work as I can only pull up the OSD when the monitors displaying through VGA - switching it to DVI though the OSD won't save the changes
Ideas?
