1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Multi Monitor Setup
Discussion in 'Monitors' started by NickM, 7 Jun 2010.
  1. NickM
    Mobster
    Ok, at the moment I have dual monitors running off the 2 DVI ports on my gfx card.
    Now I'm about to purchase a large TV and want to hook it up to my PC to watch movies etc, how do I go about doing this as both ports are being used? Do I need another gfx card?
    Thanks
  2. chrisxuk
    Mobster
    You can get splitters like in the image. However I'm not sure if these just duplicate the image over two displays, or allow for the two monitors to show different images.
    [​IMG]
  3. FrankJH
    Capodecina
    If its just movie watching you want to use the tv for I would be tempted to get a basic low end card - thereby not affecting your main dual monitor setup by continually changing back and forth
    edit - this info is more valid pre Win7 (I havent tried multi monitor setups recently so maybe different configs are easier to manage with newest OS)
  4. NickM
    Mobster
    It is windows 7 - I'm sure I remember some kind of external splitter device that allows people to use 3 monitors off one gfx card being mentioned in the Multi Monitor Setup thread but I cant find it (I assume if it can do 3 monitors it could do 2 monitors and 1 TV).
  5. Clive Dunn
    Google dvi switch box, get a 2 port one. Then have the main monitor one cable, with the second monitor and TV off the other.
    I think that works ? Sound will be interesting.
  6. NickM
    Mobster
    I'm already using an HDMI switch box to hook up my xbox/laptop to the same monitor (different setup) and its annoying because it moves my desktop icons around/sometimes screws up the resolution so I'd rather have a dedicated way of having all 3 connected at the same time.
    Sound isn't a problem as I already have the sound from my computer hooked up to my hifi.
  7. whitecrook
    Sgarrista
    Use a splitter if you monitor runs at the same res as your TV, or get an additional gfx card, or deal with juggling icons and stuf about.
  8. Alfie
    Wise Guy
    I have just asked the same question except I have a spare HDMI port. Can I run three monitors like this (all same res) even though i'm not using eyefinity?
  9. NickM
    Mobster
    Ahh managed to find what I was originally looking for: http://www.matrox.com/graphics/en/products/gxm/th2go/. Starting to think that a 2nd dedicated graphics card for the TV would be better.
    So, spec me a cheap graphics card that can run HD & BluRay on a 42-50" TV, (currently running an Nvidia 8800).
