I have a problem that has been going on for some time, and I've yet to get on top of, mainly through not having the time, and the usual life gets in the way stuff!
Built a PC last year, the essentials are:
Gigabyte GA-Z68X-UD3H-B3 Z68 Socket 1155
i5 2500K
16gig G-skill ripjaws 1600mhz DDR3
OCZ Aglity 120gig SSD
XFX HD 6870 video card
The video card came about a month after the build and I fitted a bigger power supply, of about 600 watts?
All was fine for about 3 months. Then one day I came back in and the PC was dead and wouldn't fire up. Dead power supply so replaced it under warranty.
Another month or two, and then "Bang!" the PSU went pop and all was dead! The shop who supplied the PSU said they only replaced a faulty PSU once as policy, and so in desperation I went elsewhere as I needed to get the PC working pronto!
I won't bore you all with the details, but due to a massively difficult past few months the PSU's (650, 750 and 880 watts!) have all gone bang, but leave the motherboard and all other components apparently fine and working!
I've just taken apart the last PSU to have a look (Not returning it, they would bolt the doors seeing me coming!) and there's a small 8 leg chip with it's top blown off. The source of the bang I reckon.
Cutting to the chase, I feel it's the motherboard causing this. I guess the other culprit could be the XFX 6870, but it would apparently fail when the card was at idle, and be fine when the card was working hard?
I've had the Motherboard out earlier nin the process and checked for any possible shorts/correct stand-off placement etc. I'm confident that nothing was ever wrong on that account.
Anybody had anything similar? I prepared to replace the motherboard if needed, but would like some opinion.
Many thanks.
i5 2500K
Many thanks.
