Multiple HD failures
21 Jun 2004
Since i built my current PC (3 years ago i think, when conroes launched) I have had 3 hard drive failures (with at least 2/3 additional crashes where everything was lost). All of the drives have been <1 year old and sATA. They have been a 250gb, 500gb and 1tb WD drives. Despite these failures i have an old 250gb maxtor IDE drive that runs without a problem 24/7 for 5 years.
With the 1tb drive failing when it was new in march, I have started to think that the motherboard sATA controller might be in some way be killing these drives. The last 2 failures (500gb and the 1 tb) have both resulted in multiple computers refusing to even post if they are connected as non-boot drives.
The motherboard in question is a Asus P5W DH Deluxe (no overclock)
I`m going to get the drive swapped under-warranty, but does is it possible that there is a rare and intermittent motherboard fault causing the problem? Should i change the motherboard at the same time? I`m also thinking about picking up an SSD and using a partition of either the 500 or 1tb drive as a backup.
Thanks for any suggestions
I've got a couple of 500GB WD drives in my machine and I've never had a problem with them. Like you, I built the machine about 3 years ago.
In my experience (25 years in IT, so lots of disk failures) I'd say dust and overheating are the two most common causes of disk failure. Are you sure your pc is adequately ventilated? Have you cleaned the dust filters behind the inbound air fans?
Just my initial thoughts.
Nomadd
Nomadd
Yep the sata drives have all sat infront of the front fan (120mm) which i clean fairly regularly. All failure have also happened at startup after working perfectly when they were shut-down.
do you ever update your bios? Early revisions can sometimes have problems with data corruption etc so at a push it could be the cause?
I`m going to try updating the bios, then im going to get an SSD.
Once i get the 1tb replacement back, i`ll try using a partition on that as an image backup of the SSD so i can easily restore in the future. Are there any good/cheap programs to do this?
acronis is what most people on here recommend
