Multiple Independant Hard Drive LED's?
30 Jul 2005
Midlands
i have a case which has 3 leds for hard drives and inside the case there are 3 cables for hooking up each led for a hard drive.
question is, how do i hoop up the 3 led's to the 3 different drives i have inside the pc so each drive has its own led?
is this even possible to do? the mobo only has 1 hard drive led light socket.
Only works for IDE drivers and involves modding the IDE cable. If you have basic soldering skills then you can probably do it, I would have liked to do it on mine but I'm all SATA now.
http://www.zapwizard.com/Guides/IDE/
