- 5 Aug 2006
- Derbyshire
Whilst I cannot comment on MR2, I bought my mk1 mx5 in 2012 for £900 and it has caused me few issues.
A used engine and gearbox is £125 because the cars die from rust only, as nothing else breaks.
For new parts are very cheap. I paid £30 for a new radiator when the original gave up the ghost last autumn.
A new roof fitted is £250. Same again for mid range tyres.
Is the MR2 better? It depends how you define better. Looks and performance wise I would say so but the mx5 is the perfect blend of reliability, cheap to buy, cheap to maintain, easy to maintain and fun.
Mine is SORN over winter, but each year when I get it out I let it sit a few minutes before taking it to 7k rpm and go sideways round a roundabout.
MK1 vs Mk2 wise is totally up to you. My preference is the MK1 as it is lighter and does not suffer the same rust issues as the mk2. Underneath they are nearly the same, as you can fit the mk2 dash into a mk1. The hard tops are interchangeable between MK1 and MK2. If it is a pre 1995 import then you don't have to worry about emissions as it has a de-cat MOT. Just avoid the post 1993 1.6 as it is 90hp not 115 like the earlier ones.
In 2012 I was out looking for an MR2. Ended up with an MX5.
With the MX5 only buy one that is not rusty. They are the world's best selling sports car and are literally everywhere, so wait for one that is not a turd.
I still find it mind boggling that fixing sill rust (~£200 per side) costs more than an engine and gearbox!
