Hi, Newb here
This is my 1st build I have done, ive normally just bought PCs but I decided that I was being screwed over by the levels of spec available ECT so i bit the bullet and begun my build
Coolermaster Elite 430 Windowed Case – black
Asus P7P55D-E
Core i5-760 @ 3.6GHz
Thermaltake Frio CPU cooler
2x Coolermaster SickleFlow 120mm LED case Fan
OCZ MODXSTREAM 600w PSU
Samsung Spinpoint F3 1tb
G.Skill Ripjaw 4gb 1600Mhz 8-8-8-24
Still to come as its not yet finished
Samsung BH-123L Blue Ray ROM DVD RW
LG E2250 V Widescreen LED monitor
Sapphire or XFX AMD HD6950
Currently running a IDE dvd drive and an old nvidia GPU my mate had laying around
Maxing at 60 running prime but the fans are down a bit on the cooler to reduce noise, Thinking of a couple of noctuas to quieten it down a bit
Delighted with it so far! quite proud it being my 1st build, Got it up to 3.6 just using the inbuilt tuner on the board and i'm happy with it there, im not going to push it any further as i'm sure I wont need it, Had to manually do the RAM timings ECT cant wait to get paid at the end of January to get it finished off
Some pics from start to end
Messy Cables
Tidied it up a bit
Thanks
Asus P7P55D-E
Messy Cables
Tidied it up a bit
Thanks
