My 1st ever build. Help
16 Jan 2018
Hi guys,
I didn’t ever think I would be trying to build my own pc but Today I purchased a Ghost S1 case because the minute I saw it I knew I had to have it. Anyway just after I got the order confirmation it dawned on me that I ain’t got a clue how to build a pc . I want to build the most powerful air cooled pc that I possibly can. I also just bought a noctua NH-L12 air cooling system to go in it. I was thinking of fitting a i7-8700k with a Asrock fatal1ty z370 itx motherboard. I just wanted advice as to if there is a better chipset and motherboard that will fit my noctua fan. I don’t really want to spend more then £2000 on the system and I don’t really want the best graphics card as the only game I ever play is football manager. So if you can also recommend a cheap graphics card that will do the trick I would be grateful. Thank you guys
1 Dec 2015
@Saqib99
Welcome . It's a stunning case but you'll be either looking at getting a top hat and 240mm AIO or.... 8700 non K version which will do just fine as boosts to 4.3hhz on all cores - has lower 65w TDP that the cooler you've listed Syed can handle .
Intel state TDP at light load unlike AMD who state full load. 8700 is around 80w TDP at load and 8700k 95w hits 130w when overclocked
Man of Honour
26 May 2012
for a first timer, that case is going to be a 'mare to build in. i suggest you enlist some manual help from a friend who has built computers before.
don't think you need to spend that much lol. a mid-range cpu with integrated graphics is good enough.
tbh. i'd say wait and see how good the amd am4 apus are before splashing your cash.
21 Apr 2016
Oh Canada!
I concur.
Honestly it sounds like the OP wants a fast machine "just cuz" which is fine but there are limits to what is a sane amount of money to spend on a PC for youtube/netflix/facebook/email/extremely casual gaming.
Some people are such casual users that they wouldn't notice a difference between a dual core pentium and a 16 core threadripper, or the integrated graphics on a coffee lake CPU vs a GTX 1080Ti. I think we can agree that everyone will benefit from fast storage but again there are limits to the sanity there. A casual use PC won't benefit an awful lot from a cutting edge eye-bleedingly fast M.2 drive vs an affordable SATA drive.
I have high end "mainstream" parts circa 2014/2016 (4790K, fast-ish DDR3, GTX 1080) but I "need" them for my AAA gaming addiction.
