- 28 Dec 2017
- Beds
I did a lot of thinking and some experiments last year. That was my end approach - two plates and a hollowed out middle piece. But using glue was messy, and still hard to get totally watertight. I tried specialist glues which were better but still didn't look right, stopped short of UV cure resin. At that point I decided it was a bit fiddly and complicated, and I'd be better spending time learning a new machine.Have you thought about making it from 3 plates? you could have solid front and back plates, cut all the way through the middle plate. You could cut a thin gasket from laser rubber (rather than o-rings) that gets sandwiched between the plates or probably what I would do is just permanently chemically bond them (you have no real need to ever disassemble). You could finish the edges once bonded to make it almost like a single block. I'm sure it'd work and be pretty unique! The challenge would be to avoid getting any chemical bond on the clear water channel part - perhaps you could use a dissolvable masking tape that could be washed out afterwards.
The gasket sheet is an interesting idea though, as is the dissolvable tape. Have you see it available before? I may pick up this project again for a build!
Still like to get a CNC router if I had the space though
