Hi guys, i dont normally use these forums but you have been reffered from a friend. he told me he gets the best advice from here so i thought i'd give it a whirl.
The following is the build specs i have set out for and are holding to buy. I would just like an outsider opinion on this build please.
I plan for this build to be the best and as future-proof as possible. It will be used for a whole array of things including high end gaming and video editing and much much more...
All comments and advice will be noted. Thank you in advance.
Gigabyte GA-EX58-EXTREME Intel X58 Crossfire & SLI DDR3 ATX Watercooled Motherboard - Socket LGA1366
Intel Core i7 965 EXTREME 3.20Ghz QUAD Core CPU Nehalem - Socket LGA-1366
Thermaltake VH6000LBWS Armor+ Super Tower with Watercooling- Black
Zalman ZM1000-HP Heatpipe Cooled 1000W Modular PSU
OCZ DDR3 PC3-16000 (3 x 2gb) Blade Series Low Voltage Triple Channel x 2
Western Digital VelociRaptor 300GB WD3000HLFS 16Mb Cache 10,000 RPM x 2 (RAID 0)
Seagate Barracuda 7200.11 1500GB 1.5TB ST31500341AS SATA-II 32MB Cache 3.5'' Hard Disk Drive x 5
LG GGWH20L Blu Ray ReWriter HD DVD ROM DVDRW Super Multi SATA Drive
Gigabyte ATI Radeon GV-R487X2-2GH-B 4870 X2 2048MB 2GB GDDR5 PCI-Express 2.0 x 2 (CrossFire)
Asus Xonar HDAV1.3 Deluxe HDMI 1.3 PCI-Express DTS HD Sound Card
Hauppauge WinTV-HVR-4000 Hybrid Video Recorder Quad TV Tuner
Waterblocks for both GPU's and an additional 240mm Radiator on the outer back of the case.
I dont think i've missed anything but please let me know if i have. lol
looking forward to your reponses.
Th3 D M4n
Th3 D M4n
. Still, even if you had infinite money, the 965 is sod loads more than the 940.
