- 9 Jul 2008
- Bristol
Basicly I have had my Honda XR 125 since October and love ridding it (even in snow). So basicly after an oil change, I havn't really bothered.
I had a look after work and found the following wrong
1) Chain rusty and slacking to much and can not be adjusted by pulling rear wheel as its pulled back to the max.
2)Spring missing from back break to set off break light.
3) Horn does not work due too one of the wires snapped.
4) Number plate light not working
5) Break Fluid nearly empty
So I will order a Chain/Sprocket kit off e-bay for around £50 tonight/tomorrow. and try and change the sprockets myself and chain myself. Any tips welcome
I can't locate a new spring for the break light not sure what they are called
so done a quick fix with some wire at the moment.
Not sure if I will need a new wire for the horn or if I can connect the old one back.
Order new bulb and hope it's that
Buy some dot4 fluid and mess up bleading my front break
Any idea how I can prob my bike as I don't have a Bike jack? any tips will be appriciated
.1) Chain rusty and slacking to much and can not be adjusted by pulling rear wheel as its pulled back to the max.
so done a quick fix with some wire at the moment.Not sure if I will need a new wire for the horn or if I can connect the old one back.
.Any idea how I can prob my bike as I don't have a Bike jack? any tips will be appriciated
. Well, suppose as it's only a 125cc
