- 14 Nov 2006
- UK
Ok, he started getting a boot error,
'A disk error has occurred, to restart press ctrl-alt-del'.
I first tried just restarting just to see if it would work, sometimes it would but then it would freeze on Windows loading screen or on desktop. Just went back to the same error all the time though mostly.
I've done 'chkdsk' but it froze up on stage 4 at 72%, tried it 3 times now but still doesn't complete.
I tried getting to recovery console to run 'fixmbr' command but that freezes as well, either during 1st Windows setup stage or after I press 'R' to access it, every time I try it does this. I tried to just format the drive but that froze as soon I selected to install Windows to try and format it.
I've updated the bios and reset to defaults, no change.
I just tried running DBAN to wipe the drive but wouldn't complete, it said it's usually caused by bad sectors so I'm thinking the drive is ******.
Just an endless amount of lock-ups and blank screens.
Anyone got any ideas?
Thanks.
EDIT: I've also done Memtest which found no errors after 2 hours of running.
Thanks.
