My Build
@Lee32uk, the G2 PSU is out of stock everywhere and will most likely be like that for a while, I'd recommend changing that in the spec.
And for the sake of spending an extra £20 just for a window, I'd grab a better case that has a window already, Corsair 540 springs to mind.
I just stuck the Aerocool case in as an alternative to the ops original choice.
Yeah the EVGA has been out of stock for ages. Anyway the 850W is in stock so that isn't a huge problem :D
Don't support dual channel memory? :o
I think they do, just perhaps not written on the Gigabyte/OcUK website, but all the mid-range/high-end motherboards will support dual channel DDR3, if they don't I'd be seriously worried :S
Gigabyte website shows it does support dual channel
http://www.gigabyte.com/products/product-page.aspx?pid=4959#sp
As for the case, it looks good but features wise it doesn't seems all that great - your decision though, so go for what you want!
How about something like this?
YOUR BASKET
1 x Gigabyte Z97X-Gaming 7 - Devils Canyon Core i7 4790K CPU & Motherboard Bundle **£43 Saving** £347.99
1 x Gigabyte GeForce GTX 970 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card £299.99
1 x Seasonic M12II EVO Edition 850W '80 Plus Bronze' Fully Modular Power Supply £79.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £74.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) £65.99
1 x Aerocool GT-A Window Midi-Tower - Black £59.99
1 x Raijintek EreBoss High Performance CPU Cooler Black £29.99
1 x Silverstone Cable Extension Value Bundle - Black & Red £13.16
1 x Silverstone PCI 8-Pin to 6 +2- pin PCIe Cable 25 cm - Black / Red £4.24
1 x No Molex to SATA Adapter Required £0
Total : £1,004.68 (includes shipping : £20.10).
Good luck getting that Ram under the cooler :D The Raijintek is going to cover the first Ram slot, and maybe even the second. It would probably be best to get the Kingston low profile ram.
Very good point, I'll edit that :D Cheers
YOUR BASKET
1 x Asus Maximus VII Ranger - Devils Canyon Core i7 4790K CPU & Motherboard Bundle **£34 Saving** £365.94
1 x BeQuiet Pure Power L8 730W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in £79.99
1 x Kingston HyperX 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit - Black/Red (HX24C11BRK2/8-OC) £71.99
1 x Samsung SH-224DB/RSBS 24x DVD±RW SATA ReWriter (Black) - Retail £19.99
- 1 x Silverstone 4-pin Molex to 4x SATA cable 30 cm - Black / Red £6.77
- 1 x Silverstone PCI 8-Pin to 6 +2- pin PCIe Cable 25 cm - Black / Red £4.24
Total : £1,052.00 (includes shipping : £13.75).
Ok looks like a good one.
If there is any better options for Mobo with the same processor as someone pointed out that asus has poor support. i personally have never had an issue with Asus but i have only had 1 board and its lasted years.
Most PSU's are out of stock too.
Also the below is out of stock at the minute but i dont think i will need as the other cables come with one PCIe Connecter
YOUR BASKET
Yeah you can drop the single Silverstone cable, as the bundle has 2 x pci-e cables in it.
All the PSUs that have been specced are better than that BeQuiet 730w (which has two separate 12v rails instead of a single rail, which can sometimes lead to issues in certain circumstances).
The max combined output of that BeQuiet's 12v rail is 660w, compared to the others which have the same max output (or very close to it) as what it says on the tin. Its warranty is only 3 years compared to the 5 years on the EVGA B2 I specced, which is a better PSU anyway (and is quiet if that is a concern). There are even better ones like the EVGA G2's and SuperFlower Leadex's if you want to spend a bit more.
I'd have a look at one of the phanteks , or Bitfenix cases mate, I wouldn't buy an Aerocool case again, I have the Deadsilence and the front panel is the cheapest material I've ever seen in a case, they describe it as " Leather coated " but it is just cheep plastic with an almost rubber effect to it, bloody awful.
