So, this is my PC:
http://www.packardbell.co.uk/products/desktops/imedia/imedia-2414/productsheet-PB82128501-46.html
And i upgraded it with these two parts:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-168-AS&groupid=701&catid=56&subcat=938
http://www.overclockers.co.uk/showproduct.php?prodid=CA-035-OC&groupid=701&catid=123&subcat=
After a rather tight fit, i connected everything up, adding 3 extra cables to the PSU. One was a 4 pin, that goes to my DVD drive, the other was a SATA that goes to the front of the computer where you turn it on, and the last was a cable that is a 6 pin that goes to my new GPU, as the thing that connects in the main bunch of cables was an 8 pin.
After turning it on the first time, everything was fine, the computer turned on, the new GPU installed, but then after trying to do multiple computer searches and installations at the same time, it froze. So,i held down the power button for 10 seconds and it turned off. When i go to turn it back on, it doesn't. I open up the back, fiddle with the connections, and then put everything back. The power now turns on, i start in safe mode, see everything is fine, turn it off again.
Again, it wont turn on. I do the same thing, and finally it stars normally. I turn it off again to try and fix anything for the last time, and this time, no matter what, it wont re-start. I have unplugged the PSU, waited, turned off the mains plug and kept trying, and nothing.
So, is there anything i can do to get my computer back up and running again, other than taking out all the new stuff and putting back the old stuff? I don't want to do this, but i may be forced to. Any stupid mistakes i may have made during installation that may have done this.
Lastly, while the computer was on, it was getting rather hot, and was slower than usual. Also, since i can't turn it on, i can't check if it's something to do with the software, although i highly doubt it.
