My CPU Needs?
Permabanned
6 Feb 2010
Barnsley
I have decided its time for a new system as my is dated. I am good g with amd and will looking at ryzen 1700/1700x but a friend said why not get a quad core ryzen as there me t to be killer? The ones with hyper threads
My mine use is a general home pc. But on a week end I like to game at 1440, games like battlefield and fifa
When would be the cup for me. I want the build to last a long time 3year+ would be nice.
Any of these cups will do, and they do a brilliant job ;): https://www.overclockers.co.uk/lifestyle-and-gadgets/ocuk-merchandise/mugs
As for CPUs, what's your overall budget? All Ryzen 5+ CPUs have SMT (Intel calling it HT). The quad cores will have 8 threads and works pretty well, but the 6 cores/12 threads aren't that expensive either. You could go for that and then used the money saved for a stronger GPU which will matter more on that resolution.
EDIT: Corrected
The new i5-8600K could be a good choice for you. If you only game I doubt you need an 8/16 cpu with lower single core performance. Depends on your budget though.
As for CPUs, what's your overall budget? All Ryzen CPUs have SMT (Intel calling it HT). The quad cores will have 8 threads and works pretty well, but the 6 cores/12 threads aren't that expensive either. You could go for that and then used the money saved for a stronger GPU which will matter more on that resolution.
This is not true. Ryzen 3 has no HT/SMT whatsoever.
Only Ryzen 5 4c have 8t. The ryzen 3 is 4c4t.
I like a nice C-cup, not too big, not to small. If you are going to do motorboating then the bigger the better
I once encountered some quite stunning F cups. Much motorboating ensued. The woman they were attached to was kind of weird though so it was a 1 time deal.
EDIT: Corrected
My budget is good up to the 1700x but if of of the 4c8t cpu's will do the job I word be happy to get that.
I wouldn't get just a 4c4t amd cpu.
The 7700K is sub 300 the almost identical 6700K is 250. Those are the fastest quad cores i7. But the motherboard is a dead end.
You could probably throw in the X299 quad core i7 too, but the boards are pricey and you need to carefully over clock them and seem to need a chip from a good batch.
Coffee lake will probably offer the fastest 6 cores chips. Prices are unknown and the board is also a dead end but Coffee lake could be a really good CPU if the main task is gaming.
The 1700 is 250 and the 1700X is 280. The're 8 core 16 thread chip for the price of a quad. You take a hit on performance per core but AM4 is the better platform. AMD have Ryzen + coming in February and Ryzen 2 is suppose to be coming in late 2018. AM4 is meant to support chips until 2020.
What do you currently have?
I had a 4770k but ever the board or cpu is dead.
I think at this time I would like to give amd a go. Getting the best of the best for me is not really that important I just want a good system that gets the job done
C
Could go for a 1600 now and then replace with one of the newer ones at a later date, if you want the extra performance. If your in no rush then wait for Zen+ in February, which will be 12nm and a slight advantage over the 14nm cpu's currently on offer.
