My Dial Up Connection Have Disappeared. Please HELP!
13 Jun 2006
My broadband connection suddenly stopped working. After a lot of messing about I discovered that my dial up options from Network Connections had disappeared.
If I try to create a new connection the option for dial up is greyed out.
If I try to reinstall my broadband files it freezes at the point where it is trying to load a file called createdun, this I assume is looking for dial up networking and can't find it.
Any help you can give me would be much appreciated
Thanks
Funz
Google suggests it's something to do with a BT Voyager USB modem.
Presumably by "broadband files", you mean the disk you got with the modem?
Tried spyware/virus scans?
Hi Tolien
Thanks for the reply. I am 99.99% sure that my PC is Spy, Ad and Virus free, and I also know that it can't be the modem or the BT software because I am using them on my backup laptop.
It must be an XP sp2 problem or a hardware problem of some description but before I reformat I wanted to be sure.
Thanks again
Funz
That doesn't mean squat. It's perfectly capable of breaking.
Try reinstalling it for starters, or is it the "broadband files" you were on about?
I would suggest reinstalling, but USB modems are verging on a waste of time :shrug:
