- 7 Feb 2004
One of my customers has a corrupted My Documents target on their desktop but I can not remember how to restore the function that shows the Restore Default option for this.
If you right click on My Documents then go to properties you can normally select Restore Default but those options are missing.
Any know of a fix, is it a reg setting that makes it disappear?
This is for XP by the way
Thanks
Thanks
