Hi I thought I share my build with you lot, tell me what you think:
After my stockists started to muck me around for my abit board, I decided to stick with a Asrock Conroe 945g DVI Motherboard w/ an E6400 stepping, I have been informed these clock quite high : L629B282, this is my build so far:
The board w/ cpu
then the Zalman cooler, a low profile monster, much easier to install then the intel stock cooler, my temps for a few hours now have been stable @ idle 40-42 but that should improve as time goes on:
now for my case equipped with a 120mm blowout & 80mm front intake, cheap winpower 650w Psu w/ 120mm fan:
and now the completed pc:
Im currently using Kingston 2 x 1GB PC5300 Modules, looking to clock soon will post up pics.
The board w/ cpu
and reading too much trashy literature (Custom PC)
