My engine has failed :(
I reckon you need to design some kind of quick release mechanism for the clam and engine, will make changing it the next time much faster ;)
I don't even want to think about doing that again at the moment! There's no way to make the rear clam truly easy to remove without severe modification I'm afraid :(
I've just stripped the old engine down and it was kind of as I suspected, half of number 2 cylinder's lower bearing has worn away to nothing as are a couple of others. Visually the crank looks ok but will need properly checking and regrinding. The main bearings seem pretty much ok.
Main bearings ok but big ends done for :( Damn dude, hows the crank looking?
Visually it is ok but will almost certainly need work on it.
Replacement engine is done apart from:
- Flywheel and clutch to go on
- Timing to Set
- Big end bolts to change when they come tomorrow
- Sump to be stuck on
Replacement engine is all built and in. Timing chain cover still to go in, then every other ancilliary, pipe, connecter, exhaust, supercharger etc needs to go on.
Then I can start it and see what happens!
oil starvation as in not enough, pump not pumping enough, getting too hot so too thin, g forces preventing the pick up from picking up, or the dodgy dip stick
As it stands now, engine in but by no means connected. The engine needs to be dropped almost perfectly vertically to get it in which is quite tricky.
Simon - I don't know how hot the oil got, there isn't a temperature gauge as standard, but I will probably have one for the new engine.
It was simply the low oil level that I think caused insufficient lubrication of the the big end bearings causing excessive wear and maybe them to spin.
It didn't grenade the engine or anything but caused sufficent damage/metal bits to circulate that taking the engine out was the only option.
Here's an example of one of the big end bearings:
new crank I take it?
thats lovely looking :(
can you describe what happened to the oil feed hole? that looks odd
It's just covered by half a bearing which has worn completely through!
The crank will just be sold to someone who wants to experiment or have it reground.
The first we felt was that it was down on power, but on track it's loud and you've got helmets on. I'm sure the knocking may have become apparent more early in normal use.
Ah that makes sense now, ouch. I'm rebuilding a conrod shell slip, and a little bit wear.. but that takes the buscuit. I can see how you ended up with fragments everywhere if it did actually wear all the way through. Don't let it happen again! :p
The big ends went in my s13 and weren't anywhere near as worn as that. Yet there was a distinct knocking between 3-4krpm.
Similar with my old gt4, although I drove it for a couple of months before taking it of road and there was still more of the bearing left than that.
But as mucher said, on track with helmet etc it would be may have been harder to hear.
I now need to remove the exhaust, 4 tricky bolts on the supercharger to do up, SC belt on, mount a bracket underneath the inlet manifold and fix what I hope is an oil leak from where the dipstick enters the sump, then I can turn it over for the first time.
Just been to the breakers to finally collect the 182k engine I bought from a breakers which I am going to sell off.
Helpfully they decided to deliver it to me for free as they live just around the corner. Unhelpfully I think it's going to arrive with pretty much half a Vectra front end attached to it!!!
