- 1 Apr 2009
yes.
Not sure about the fan controller and extra fans. IMO, I would try without, then it's something you can add on later if it's too noisy, too hot.
On that subject, I would probably pick up another motherboard, like a P8Z68-V, which has better fan tweaks (case and CPU fans) than the GD65.
Honestly I keep my computer on nearly 24HRS and noise honestly doesn't bother me i can probably sleep throw a hurricane, i actually sleep with music on in general - I generally would prefer a good cooling system. The fan controller i dont know it seem pretty sweet just a personal bonus to my system.
"P8Z68-V, which has better fan tweaks (case and CPU fans)" what do you mean if i have a fan controller well 4 channel should i say i wouldn't really need that anyway why wouldn't my current one have exactly the same features?
Also Asus i have read and heard a lot of bad **** with there boards and the MSI i haven't heard just as much bad press from users and raters as Asus![]()
Ide go with at least a 1000 w psu.
As for hard drives Samsung SpinPoint f3,s in raid 0 fly.
I read that over-powering your system can fry it how certain can i be that i wont fry my system with a 600Watt power-supply?
It will only use what it needs plus a little used up converting into different voltages. only thing with getting a too powerful psu it will be less efficient if only using 40% the power compared to using a smaller one at 80%
You asked if there were any bottlenecks, well the mechanical HDD is a big one! Can you shift any of your parts budget onto an SSD?![]()
