My First Build Topic :D
Ok I plugged in the HD Audio one.
Can anyone confirm if I plug the Corsair H50 PUMP into the CPU Fan slot or System Fan slot?
Finally do I need 2 PCI-E adaptors for the 4890?
Will most likely be 2x 6pin for 4890. My 4870's are 2X 6pin, and it's a very similar card.
Plug the H50 Pump into the sysfan header ^^^ read my post above.
Your idle temps are fine -it's your load temps that are important.
Download some stress/benchmarking apps to test for stability and temps.
Installing Win 7 64bit right now..
Well that was the quickest windows install I've ever done, it only took 5 minutes lol.
Usually takes 30 mins.
