my first build
thanks for the reply and i will look in to the case and spec you sugested but overclockers do state that the thermaltakes vapor cooling is 20ºC cooler than liquid cooling System.
as for the Blu-Ray rewriter i want it so that i can burn my fav tv shows to just one or two disks.
kk, but honestly, with regards to the Thermaltake case, you're better off throwing your money down a drain, then aiming fire arrows at it, burning it, then pouring rats ontop of it to eat it.
What's stated on OcUK is usually just marketing speil and doesn't really mean anything.
Proper liquid cooling (or anything other than air) is only good with third-party equipment, build with separately acquired parts and is usually suitably expensive.
ok thank you could some one please spec me the components i would need to water cool my system and would it be ok to just stick with my current case its a Cooler Master cosmos 1000.
and it doesnt matter about the water cooling price i just want the best cooling and system i can get for £2000 as i am not trying to save money i am happy to spend just about what it takes. thanks onetime and Chimerical u have been a great help
i have tried to take in what has been said and have changed my spec so before i post for a water cooling spec in the cooling forum is there any thing else i should change thank you .
Its good except for the Antec 900 case, which is sucky sucky and will be terrible for watercooling anyway.
You also, ideally, need a 320GB boot drive, as 1TB sucks as a boot disk.
You def do not need 1200W either, waste tbh, 850W is fine if you want watercooling as well (Be Quiet is a good brand though). Plus, that CPU is OEM, so doesn't come with a Cooler/HSF, just so you know.
thanks very much Chimerical you have been a great help now i'll post over at the cooling section, once again thank you as i would still be stuck trying to figure it out with out you.
