My First Build :)
cheers mate
that tints have settled now and look fine so think its dark enough :)
Looking for a new cooler now cos I cannot live with this stock one :/
well I had a lot of space infront of the PSU so I thought i'd try and fill it abit,
I had a cheap fan controller lying about so threw that in as my top and rear fans were @ 12v and annoying me with their noise
looks ok I think,
fans are quieter and ambients havent changed so sorted :)
Also fitted a lot more SMD's for a more even light cast :)
(I know, messy wires but I'm not intending on keeping this case. want an Antec 1200)
Cheers
Just fitted my Arctic Cooling Freezer 7 Rev. 2
Not really changed the idle temps as they were pretty low anyway (33-34c)
Load temps now only 51c @ 3.61HGz and it a lot quieter than the stock cooler and I have now fired up the case side fan without it interfering so happy :)
Cheers
Cheers dude
I'm still playing with the idea of actually drilling holes in my prespex so I dont have to open the case to adjust it,
However I don't think I should as once its set to the right setting, It pretty much gets left alone,
dont know if its worth the drilling lol
cheers lol
Am re-doing it though as this was just a test one,
It takes ages to clear up all the nodes for a decent cutting image for the vinyl plotter and didn't wanna put the effort in if it was gonna look crap lol
Looks pretty good some gonna do a proper design
But by all means feel free to copy it
I think there may be a few i7 980X owners running at 4.5GHz that would disagree with the sentiment of the HSF decal to be fair.
Still looks like a nice tidy build, I think the black interior helps finish it off.
Am I right in thinking that that case has massive positive air pressure?
Now you just need to tidy up your desktop! :)
The decal is just personal preference (the whole Intel vs AMD thing)
I personally prefer AMD and will never own an Intel CPU
the 2 250mm fans are only spinning very slowly so I don't think that it has positive pressure
plus theres too many holes in the case so its no where near air tight
Decided I like my case now so going to keep it, get some PSU extention cables, braiding and cut some holes in the motherboard plate for some cable management :)
