- 9 Nov 2006
Hi everyone how you all doing?
Built a Conroe e6600 (not sure its week etc) bought from ocuk of course..
Aw9d Max board:
Corsair Dominator pc8500 C5 (still got it set at 5-5-5-15)
Galaxy 850w psu...
Edit: Cpu cooler is a BigTyphoon
Temp on the general cpu guru toolkit is reading 32 on a non humid evening to 34-35 fluctuating..
Got the machine running stock install speeds etc right now, guru says clock is
266mhz
memory is i think recall set to SPD not CPU .. its probably on a 4:5 ratio i think..
for my first ever time clocking, (ive read the sticky posts and then gone to other links from that one etc, mind blowing for me as i worry about everything i just bought heheh)
Just wondering if anyone with similiar setup, or can give me a few things to adjust primarily just to get to maybe 3ghz safely that would be great, the thing im totaly unsure of is getting the memory to be at the best possible speed, as it is i believe 1066mhz which would show as what ? 500 something or should for optimum in the bios ?
see at a loss lol, im sure someone can help you all seem pretty much clued up it seems
run some tools etc to show basic setup:
http://img247.imageshack.us/my.php?image=11112006121422dg2.jpg
Thanks in advance,,
James..
Aw9d Max board:
Galaxy 850w psu...
266mhz
Thanks in advance,,
James..
