- 10 Sep 2008
- Macclesfield, U.K.
Hi, I have tri channel like doiks said, its cheap. Well it was on offer and so was cheaper than dual, and when its in there it runs as dual and a single.
Thus geting me low volt hi spec ram with great heat sink for F'all money. Im hoping to try and convince some one to buy the same set again but for dual use n id buy one off them to give me 2 dual sets totaling 8GB. The tri ram is only 'optimised' for tri boards, it stil runs fine in duals.
I wanted a crazy case, but i dont like the usualy sleek elegant gamer cases that look like space ships. This had more of a military feel so i went for it, plus the cooling is epic in it.
I will ask in the clocking part of the board for help, prob sum point tomoro then if win 7 is ok.
The converting of the case wont happen till summerish, its going to be my little project
Plus i need to find a short pink cathode to hide in the drive bay area to glow from the front.
