My first full build, HTPC pics etc...
17 Jul 2015
Hi all, just thought i'd share the specs and pics of my first full pc build :) I'm going to replace the stock 140mm corsair fan for a Noctua unit.
Comments welcome.
Spec:
Case - Corsair 250D
Mohterboard - Asus B150i pro gaming/wifi/aura
CPU - i3 6100
CPU Cooler - Noctua NH-L9i
GPU - MSI GTX970
PSU - Corsair RM850X
RAM - Kingston HyperX 16GB FURY Black Heatsink (2x8GB) DDR4 2133Mz
SSD - Kingston UV400 240gb ssd
HDD - WD Green 2TB
Blu ray drive - Pioneer BDR-S09XLT
Case Fans - 2 x Nzxt 120mm 1 x 140mm LED Corsair
Windows - 10 Home 64bit
Forgot the GPU in the pic :(
Ha ha I know. I upgraded the main pc so used the one from that for this. The fans don't move under light/medium load so is silent :)
Got you. The way you showed it boxed implied that it was purchased for this build.
I'm building a similar rig myself, but just for file storage\DNLA server etc hence the interest.
I was looking at the T version of the i3 6100, as it's only a 35W part. Might help keep the noise\temps down a little further!
This idles at 29/30°c.
How do you check the watts?
With something like this:
http://www.reuk.co.uk/Kill-a-Watt.htm
Or just search online for "watt meter", "energy meter", "power meter", etc.
They range in price from 10€ to 50€.
Note: this is not suitable for measuring wattage of individual components, though. As in, you can't measure only GPU or CPU.
For individual components, you can try something like this:
http://www.silentpcreview.com/Zalman_CPU_VGA_Power_Meter
But from what I've read, it's not actually that accurate. Nevertheless, it should still give a fairly decent ballpark to compare.
Ah OK just wondered if I could use an app. Not bothered about the power usage so I'll pass on buying something. Thanks.
