- 29 Dec 2005
oh dear, I decided to have a go, didnt have a clue what im doing though
1.8ghz 2200+ athlon socketA cpu, stock cooler
gigabite agp board nforce2??
1gb of elixer memory
started with 133mhz, changed it to manual settings, rturned it up slowly to 140mhz, it wouldnt start windows, turned the voltage up buy 0.1v and it would start, kept crashing, was getting 1.89ghz which isnt much I know, just wondering how far i can go, also there are other things like voltage % for DIMM and stuff and I dont know what they mean
start off very slowly. maybe you should invest in a powerful cooler if ** still using the stock one. stock ones are poop!
